Discussion topic: Broadband speed
Message posted on 15 Aug 2024 12:12 PM
Broadband speed
I am only getting 32mbs when I stand beside my router and even less when I go upstairs. I have recently got a new router that has not helped. I am guaranteed alot more than 32. I need this fixed or I will have to go with a different supplier
Message posted on 15 Aug 2024 12:16 PM
Re: Broadband speed
@gavinduff44black or white router from Sky?
Message posted on 15 Aug 2024 12:36 PM
Re: Broadband speed
Black router
Message posted on 15 Aug 2024 12:43 PM
Re: Broadband speed
Guaranteed Minimum Download Speed is not the same thing as a WiFi Guarantee (which really isn't)
If speed reaching your Hub is below GMDS then you need to log a fault with Sky for investigation by Openreach.
The WiFi Guarantee applicable to your address depends on which subscription supplement (if any) you have in place.
Message posted on 15 Aug 2024 01:57 PM
Re: Broadband speed
@gavinduff44 Could you please post your router stats following the link below.
