Discussion topic: Broadband setup
Message posted on 21 Mar 2025 04:17 PM
Broadband setup
if I take sky full fibre 150 broadband do they set it up for me in my home or do they just send the router and I have to set it up myself?
Message posted on 21 Mar 2025 06:02 PM
Re: Broadband setup
@hectory the standard install calls for the engineer to conect you new hub and one device of yours to thst hub. to demonstate it is wotking.
Message posted on 22 Mar 2025 11:40 AM
Re: Broadband setup
Thanks you for the quick reply, much appreciated.
Message posted on 22 Mar 2025 02:26 PM - last edited: 22 Mar 2025 02:27 PM
Re: Broadband setup
If there's not an existing FTTP circuit and Openreach ONT at the address then installer attendance is required (sometimes with more than one visit )
If you have that already then a Hub will be sent out and no-one will attend.
