Discussion topic: Broadband outage
This message was authored by: Hedgieboy
Broadband outage
Hi do know when my broadband will be fix as I be 24hrs with broadband which is a disgrace
Re: Broadband outage
@Hedgieboy
As customers here who help each other we can not answer this.
So the  first thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
If this is if no help give Sky a call to report it to them.
@Hedgieboy
Broadband is not a 24/7 guaranteed service. Being without it for 24hrs is far from a disgrace. The standard fault fix SLA from Openreach is 2 working days after the fault is reported. If you need a broadband service that has a higher SLA you should opt for a business grade line.
I am NOT a Sky Employee
@Hedgieboy wrote:
which is a disgrace
@Hedgieboy
In the UK two WORKING days is the service level agreement between ISP’s and Openreach for fixing a fault.
