Discussion topic: Setup sky max hub
This message was authored by: Sergio77
Setup sky max hub
Code on box no help to setup my new SKY MAX HUB, assistance should be provided . Need help to get it to work
Re: Setup sky max hub
Hi @Sergio77
What code are you referring to? The setup of the Sky Max hub should be as simple as plugging it into your telephone socket or Openreach ONT depending on the connection method available at your home.
I am NOT a Sky Employee
