Discussion topic: Broadband not working
Message posted on 13 Oct 2025 09:22 PM
Broadband is t working.
i have switched the hub on and off and reset it
Message posted on 13 Oct 2025 10:05 PM
Re: Broadband not working
@Clare141 You just need to check what is going on the lights tell you what is happening to the hub, and all this off/on and reset's does not help in the slightest when you have NO idea what or why it has happened! Links below may help you find out the what/why!
