Discussion topic: Broadband not working
This message was authored by: Sandy1919
My broadband is not working. The first and this light are green. The 2nd light occasionally flashes orange and the fourth light is off permanently. I have reset the router twice, but nothing has changed.
Re: Broadband not working
@Sandy1919
The wait for any necessary Openreach visit will still be delayed due to the disruption from the recent storms.
