Discussion topic: No WiFi
Message posted on 28 Jan 2025 07:47 PM
No WiFi
Hello,
although my Sky App tells me my WiFi/broadband is ok, I have not had WiFi since Sunday. I have tried resetting it. I work from home and desperately need this sorting.
Message posted on 28 Jan 2025 07:58 PM
Re: No WiFi
@Laura17
If the service checker is still not telling you that Sky are aware you may need to call them to report it (dial 150 free from your Sky Talk landline). Remember wfh brings no quicker response on what is a domestic subscription.
The wait for any necessary Openreach visit will still be delayed due to the disruption from the recent storms.
