Discussion topic: Broadband issues
Message posted on ‎06 Feb 2024 12:24 PM
Broadband issues
Hello, any advice on this?
Recently we've noticed fairly frequent [ie almost nightly] wi-fi disconnection on devices such as mobiles. Switching the Sky router on and off [and disconnecting/reconnecting router cables] restores it, but then the same issue recurs, usually in the evenings. Numerous reboots of the router have been required in recent days. A service check shows that our speed is consistently approx. 60Mb/s and has been since at least the start of January - which the MySky app acknowledges is below the guaranteed minimum download speed of 67.7Mb/s. We also noticed one night that wi-fi was suddenly only available in rooms with Sky Q box or mini-box where the signal is boosted - going marginally outside those areas led to loss of wi-fi so the mobile would go to 5G or 4G. You could then reconnect to the router, but not for long. This is highly unusual - I don't think it's ever happened before. Again, rebooting the router does help but it hasn't stopped the issue recurring. We went through the 'let's fix it' steps on the MySky app in terms of broadband which basically involves rebooting router and disconnecting/reconnecting cables. It comes back saying "you're back up and running" but then when you run the service check again, broadband issues are flagged up - so you are back to square one.
Until now, we haven't had any real issues apart from a while ago {July 2023) when the Sky Q box would disconnect from the router almost nightly, and we'd have to reboot the box and/or router or use WPS etc. That hasn't been an issue for a while, though when it happened it did affect wi-fi as the Sky Q box quite effectively boosts the wi fi signal. I flagged this to Sky who said there wasn't an issue with the hardware and to use WPS etc. to reconnect. After a while this issue seemed to go away.
Last night the Sky Q box - while on standby - made a fairly loud noise and wouldn't switch back on with the remote or using the power button on the box. I disconnected the power cable and it came back on as normal, connected to the router without any issue [didn't have to manually reconnect]. Not sure if this is linked to problems above or not.
Given that we've gone from not many issues to regularly experiencing issues, something is obviously up - any ideas? There is clearly an isssue which Sky acknowledges on the app in terms of broadband speed.
Many thanks!
Message posted on ‎06 Feb 2024 01:13 PM
Re: Broadband issues
Hi @GrahamG76
Please post your router stats
Message posted on ‎06 Feb 2024 01:56 PM
thanks I will do asap, not currently connected to home broadband
Message posted on ‎06 Feb 2024 05:24 PM
Message posted on ‎06 Feb 2024 05:48 PM
Hi @GrahamG76
Your screenshot shows the connection to your hub dropped only 6mins before you took the screenshot. Did you notice the issue you were describing in your original post then or not?
If not can you please post your stats again when you next notice the issue occuring (I assume that will be tonight)
Message posted on ‎06 Feb 2024 06:47 PM
Yes - there was an issue - the Sky Q hub had disconnected from the router for a period of time just before that screenshot was taken [now reconnected] though no apparent issue connecting mobile devices to wi fi. I will check again and post router stats later.
Message posted on ‎06 Feb 2024 11:18 PM
Message posted on ‎06 Feb 2024 11:25 PM
Those are the router stats at 11.20pm. As an update, I have contacted Sky and they have escalated the issue to begin the compensation process as speed is below the minimum guarantee. So I need to wait to hear back from there. An engineer visit is possible. A new router didn't come up as an option for the person I was speaking to who was very patient! But he felt it perhaps should have been an option. We also did a hard re-set of the router and power cycle which seemed to boost speeds quite a bit but still just shy of the minimum 67 guarantee. So the router stats provided came after the call and the hard re-set etc. The adviser said on the Sky Q hub, after I mentioned the issue raised earlier, to change the automatic standby setting to active rather than eco. It is currently connected to the router. Hopefully faults won't recur but I am waiting to hear more from escalation.
