Discussion topic: Broadband drops out every 30 mins
This message was authored by: MerrickJ
I have ultrafast broadband. Sky router connected to Openreach. Broadband drops out and lights on router go out every 30 mins on average.
It's seriously disrupting my home working and not what I expect for what I pay Sky every month.
Re: Broadband drops out every 30 mins
@MerrickJ
Could you post your hub stats
Avatar for MerrickJ
@MerrickJ
Every thing went down between 52 and 54 minutes ago . Was this you rebooting the hub .
Could you log unto the hub again and go to advanced and post the syslog
@MerrickJ
Apologies go to "support" and post the syslog
Avatar for MerrickJ
Yes I rebooted (again) to try and fix it.
You'll have to help me find the syslog sorry!
Avatar for MerrickJ
Ah. Just tried that and got this error
Your message contains 01-01 00, which is not allowed or has been repeated too many times. We block information which can identify you such as account or phone numbers & email addresses. Please remove or change it before trying again.
@MerrickJ
The syslog is in the "support"section of the sky hub interface not the advanced
@MerrickJ
You may have to edit the date and time stamps out before posting
Avatar for MerrickJ
1970-  00:00:21 syslog: [    0.215000] brcmboard registered
1970-  00:00:21 syslog: [   19.536000] eth2 (Ext switch port: 2) (Logical Port: 10) Link UP 10 mbps half duplex
1970-  00:00:21 syslog: [   20.493000] eth0 (Ext switch port: 0) (Logical Port: 😎 Link UP 1000 mbps full duplex
1970-  00:00:21 syslog: [   20.523000] eth1 (Ext switch port: 1) (Logical Port: 9) Link UP 1000 mbps full duplex
1970-  00:00:21 syslog: [   20.580000] eth3 (Ext switch port: 4) (Logical Port: 12) Link UP 1000 mbps full duplex
1970-  00:00:22 syslog: [   21.509000] eth0 (Ext switch port: 0) (Logical Port: 😎 Link DOWN.
1970-  00:00:22 syslog: [   21.540000] eth1 (Ext switch port: 1) (Logical Port: 9) Link DOWN.
1970-  00:00:22 syslog: [   21.569000] eth2 (Ext switch port: 2) (Logical Port: 10) Link DOWN.
1970-  00:00:22 syslog: [   21.600000] eth3 (Ext switch port: 4) (Logical Port: 12) Link DOWN.
1970-  00:00:24 syslog: [   23.567000] eth1 (Ext switch port: 1) (Logical Port: 9) Link UP 1000 mbps full duplex
1970-  00:00:24 syslog: [   23.605000] eth2 (Ext switch port: 2) (Logical Port: 10) Link UP 10 mbps half duplex
1970-  00:00:25 syslog: [   24.569000] eth0 (Ext switch port: 0) (Logical Port: 😎 Link UP 1000 mbps full duplex
1970-  00:00:25 syslog: [   24.661000] eth3 (Ext switch port: 4) (Logical Port: 12) Link UP 1000 mbps full duplex
1970-  00:00:53 syslog: [   40.163000] Line 0: xDSL link down
1970-  00:00:59 syslog: [   54.181000] Line 0: xDSL link down
1970-  00:01:03 syslog: Voice Configured
1970-  00:01:07 syslog: Voice Initialized
1970-  00:01:07 syslog: Voice Connecting
1970-  00:01:14 syslog: [   74.181000] Line 0: xDSL link down
1970-  00:01:17 syslog: Voice Disconnected
1970-  00:01:54 syslog: sky dhcpc client (v0.0.1) started
1970-  00:02:06 syslog: sky dhcpc client (v0.0.1) started
1970-  00:02:13 syslog: eth3.1 – WAN link UP.
1970-  00:02:13 syslog: Received valid DHCP lease from server.  Connection UP.
1970-  00:02:14 syslog: Connection Up. SNO/MAC/IP/SWVER/IPv6: [D210229C023137/3C457AE2AF70/94.8.239.161/7.03.0509.R/::1]
1970-  00:02:14 syslog: Send out NTP request to ntp1.isp.sky.com
1970-  00:02:14 syslog: Time has been set from ntp1.isp.sky.com
2024-  12:01:47 syslog: Received NTP Sync Reply from ntp1.isp.sky.com
2024-  12:01:56 syslog: WAN IPV6 UP
2024-  12:01:56 syslog: Voice IP Connection Up: 2a02:c7c:bed0:ea00::1/64
2024-  12:01:58 syslog: Connection Up. SNO/MAC/IP/SWVER/IPv6: [D210229C023137/3C457AE2AF70/94.8.239.161/7.03.0509.R/2a02:c7c:bed0:ea00::1]
2024-  12:02:00 syslog: TR69: Connect to Production ACS
2024-  12:02:00 syslog: TR69: Connection to ACS Complete
2024-  12:02:06 syslog: Voice Configured
2024-  12:02:07 syslog: TR69: Close ACS Connection
2024-  12:02:10 syslog: Voice Initialized
2024-  12:02:10 syslog: Voice Connecting
2024-  12:02:10 syslog: Voice HARDENING
2024-  12:02:10 syslog: Voice Connected
2024-  12:02:11 syslog: Voice Disconnected
2024-  12:02:16 syslog: Voice DeInitialized
2024-  12:02:18 syslog: Voice Configured
2024-  12:02:22 syslog: Voice Initialized
2024-  12:02:22 syslog: Voice Connecting
2024-  12:02:22 syslog: Voice Connected
2024-  12:26:14 syslog: Lease renewed 3600 ip 94.8.239.161
2024-  12:31:43 syslog: WAN IPV6 UP
2024-  12:51:27 syslog: Lease renewed 3600 ip 94.8.239.161
2024-  13:01:43 syslog: WAN IPV6 UP
Avatar for MerrickJ
Does that help?
@MerrickJ
'2024-  12:02:11 syslog: Voice Disconnected"
Only thing i can see after network time protocol kicks in is the voice disconnecting .  This an usualy be fixed temporarily via rebooting the hub
Other than that would advise you to contact sky or we can escalate
@MerrickJ
Also which ethernet port on the sky hub is the ethernet from the ont plugged into?
Avatar for MerrickJ
ont? What's that sorry?
@MerrickJ
Optical network terminal
Should be etherneted to lan port 4 marked wan in red
