Discussion topic: Broadband connection query
This message was authored by: figi24
I'm thinking of getting a Sky tv & broadband package. Does the broadband router need to be plugged into a phone port? I want the router in a different room to the phone connection
This message was authored by: Waveman
Re: Broadband connection query
It depends!
If you order a 'Full Fiber' package, typically 100mbs+ then Sky will contract Openreach or City Fibre to run a fibre to you home, they will also install the ONT (Optical Network Terminal) to your wall. There is 'some' flexability as to wher ethis can be installed, usually what ever is easiest for the installer!
You will need to eneter your details into The sky broadband checker to see what is available. If you already have broadband, its probably deliered over the phone lines as ADSL, if fiber is not available in your area then the Sky router will continue to use the phone line.
You can use Openreach Fibre checker at https://www.openreach.com/fibre-checker
I remember the Internet starting!
Sky Full Fibre & Virgin Media XGS-PON, with automatic failover using DrayTek multi WAN router.
Sky Q, which will be sadly missed when they decide to kill it off!
Avatar for figi24
Thanks for your reply. I checked what connection is available in our area & full fibre is coming next year. We currently have part fibre
@figi24 Then you have to connect the sky hub to the OR Master Phone socket to get Broadband there is no otherway to do it, you can look at getting a longer VDSL cable to move the hub to where you need it, but longer cable may slow the hub down slightly speed wise!
Cable type will all depend on the connection that you have currently and are using, but the NORM is an Rj11 to Rj11 connection. Extension phone sockets may go dead but it all depends on what is done and if you are made to go digital phone connecting a landline to the back off the sky hub!
