Discussion topic: Broadband and WiFi keeps dropping continuously
Message posted on 20 Mar 2024 07:21 PM
My Broadband and WiFi keeps constantly dropping. My TV says I have no Internet connection, and says I have a problem connecting to my router, but when I run tests, everything comes back as all ok.
Same with iPads and laptops, and we both work from home so this is becoming very annoying. Nothing seems to fix the issues
Message posted on 20 Mar 2024 07:32 PM
Re: Broadband and WiFi keeps dropping continuously
Message posted on 20 Mar 2024 07:35 PM
@Joobee Could you please post your router stats following the link below.
Message posted on 20 Mar 2024 08:19 PM
Port Status TxPkts RxPkts Collision Pkts Tx b/s Rx b/s Up Time WAN MER 41384 81592 0 3946 20785 00:26:57 LAN Down 0 0 0 0 0 00:00:00 WLAN (2.4 GHz) Up 58279 17869 0 2942 1331 00:26:39 WLAN (5 GHz) Up 35737 26890 0 396832 17844 00:18:24
Message posted on 21 Mar 2024 11:15 AM
Hi @Joobee
The stats you posted are not that useful as the router was rebooted only 28mins before. Can you please post your router stats again after the next time you notice a drop but before you reboot the router if you need to reboot it
