Discussion topic: Broadband Speeds
Message posted on 03 Feb 2025 10:06 AM
Broadband Speeds
Hello,
I have the Sky Max Hub Superfast 80 and have had this since September. My wifi is considerably slow especially when my PC and PS4 is on. I have looked to upgrade but it only says i can upgrade to Sky Wifi Max. Has anyone used this? It doesn't give me any details on the Mb/s so i am unable to compare the two.
If anyone has been in the same situation please let me know, Thanks!
Message posted on 03 Feb 2025 10:13 AM
Re: Broadband Speeds
@LucasAntoni Sky WiFi max won't increase your current speeds, its a monthly add on that offers wall to wall WiFi guarantee, parental controls, advanced security and the cost of weekend engineer visits waived.
The WiFi guarantee is only 10mbps on your package which may be worse than your currently getting, and some report far worse WiFi coverage with the Max hub than with the standard one.
Message posted on 03 Feb 2025 10:20 AM
Thank you! this is very helpful!
