Discussion topic: Broadband Box
This message was authored by: Georhoward1
Broadband Box
The box that was put in about a mouth ago... There is olny 3 lights on... The 2nd from the left is out... What can be dun about it ... If you can                                         Thank you
Re: Broadband Box
@Georhoward1
We don't know which hub you were issued with. The below link explains the lights on the various hubs
▪️I AM NOT A SKY EMPLOYEE ▪️
Avatar for Georhoward1
Level 0 icon
Re: Broadband Box
There is One light out the 2nd one from the left.. So when can you fix it plase ASAP   Thank you
Re: Broadband Box
"We" are not Sky, just other customers. Has it actually stopped working?
Re: Broadband Box
@Georhoward1 There is names and letters under the lights for you to also read, run the service checker on a mobile device to see what it reports in case there is an area wide network issue that sky do know about.
