Discussion topic: Wifi down
Message posted on 19 May 2025 02:27 PM
Wifi down
I'm getting no wifi at the moment
Message posted on 19 May 2025 02:29 PM
Re: Wifi down
@Rick211
Wi-Fi is the connection between devices and your hub. Broadband is the actual internet connection provided by the ISP (in this case Sky).
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
