3
This discussion topic has been answered Discussion topic: 2.4GHZ
This message was authored by: ScottWright
2.4GHZ
Im trying to connect a device to my WiFi that requires 2.4GHz. How do I do this
This message was authored by: jamesn123 Answer
Re: 2.4GHZ
Hi @ScottWright
Typically devices should still connect as your router broadcasts both a 2.4ghz & 5ghz WiFi signal. If your unable to connect it you may need to temporarily split the bands. If you let us know which Sky hub you have then instructions can be provided.  https://www.sky.com/help/articles/set-up-hub-which-sky-hub-do-you-have
I am NOT a Sky Employee
Re: 2.4GHZ
Hi @ScottWright
Avatar for ScottWright
Re: 2.4GHZ
Hi, thank you for the prompt reply. We have a sky broadband hub (the black rectangular one)
Re: 2.4GHZ
Hi @ScottWright
You can find the guide on how to split the bands here https://helpforum.sky.com/t5/Broadband-Talk/How-to-separate-WiFi-bands/ba-p/3530610
Once you've done that you should be able to connect the device.
