Discussion topic: 2.4 devices don’t work
Message posted on 20 Sep 2025 09:57 AM
I have never had any issues with my teckin WiFi plugs, Smart Life WiFi plug sockets, Swann cameras and Ring doorbell until installing the sky max hub (white box). I had a sky engineer here yesterday for 2 hours and he left scratching his head unable to resolve the connection issues. Has anyone else been able to resolve this issue?
Message posted on 20 Sep 2025 10:36 AM
Re: 2.4 devices don’t work
Hi @Debrossi Have you tried temporary disabling the 5 GHz band and then trying to connect your 2.4 GHz devices? Once connected, you can enable the 5 GHx band again.
Message posted on 20 Sep 2025 12:48 PM
With a white Max Hub you may need to reduce the wireless security level from WPA3 to WPA2-PSK using the Hub settings in the My Sky app.
Message posted on 20 Sep 2025 04:47 PM
Thanks for this advice however this was one of many tasks tried and it made no difference 🥴
Message posted on 20 Sep 2025 04:48 PM
Yes this was tried and again failed to resolve the issue 🤨
