Discussion topic: Low speed
Message posted on 20 Sep 2025 09:46 AM
Low speed
Hi, it seems my download speed is very low considering the package deal I am with, 30mb/s although I have a 500mb deal. The power of the signal seems fine. I have the feeling I am not getting consistently the min guaranteed speed which is disappointing considering also the price of the package.
Message posted on 20 Sep 2025 09:48 AM
Re: Low speed
Ring sky and ask them to check your network
Message posted on 20 Sep 2025 04:36 PM
Re: Low speed
Cabled the speed is what should be, 500mb/s, but the WiFi is poor even if I am close by the router. If I reboot the open reach box, then the speed of WiFi goes back to what should be but tends to drop again...
Message posted on 20 Sep 2025 04:48 PM
Re: Low speed
@VvEmanuele Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surface then the only answer is additional wifi sources.
Another problem thst could be sffecting your network is interference from neighbours' WiFi networks which would explain the temporary improvement after a crebootvwherecthe hub uses the least congested channels but these gradually become busier as other routers change the channels they use.
