Discussion topic: planner with saved programs is not working??
Message posted on 05 Jul 2020 08:23 PM
Hi my second sky + box is not recording and the planner with saved programs is not working??
on screen message is Sky + playback and recording are unavailable but I pay for second box
Message posted on 05 Jul 2020 08:26 PM
Re: planner with saved programs is not working??
Are both coax cables firmly secured to the back of the box, and at the other end on the LNB?
First thing to try, if you haven't already, is to switch the box off at the plug for 4 minutes.
If that doesn't fix it, try a Planner Rebuild: https://www.sky.com/help/home/sky-tv/sky-tv-plus/sky-plus-watching-sky-tv/sky-plus-recordings/diagno...
If you get a diskless mode error when you try the Planner Rebuild, it's likely that the hard disk has failed, and the box will need to be replaced.
Message posted on 05 Jul 2020 08:28 PM
Try a planner rebuild @cassscoj :
https://www.sky.com/help/articles/recording-selection-failed-sky-plus
Message posted on 05 Jun 2021 05:53 PM
My second sky box has stopped recording and I cannot play shows already recorded. Live pause and rewind are also unavailable
Message posted on 05 Jun 2021 05:54 PM
It seems I might have a hard disk fail and may require a new sky box. How can I get one of these
Message posted on 05 Jun 2021 06:07 PM
