This discussion topic is read only Discussion topic: iPlayer UHD?
This message was authored by: trevforum
iPlayer UHD?
I notice that the iPlayer App on Sky Q lists UHD programs e.g. Peaky Blinders but get a black screen with sound while trying to play a UHD stream.
Sky Stream, Sky Glass, Philips 77OLED+950, Pioneer LX-901 7.1.4, EE 900 FTTP
Locked
Re: iPlayer UHD?
Hi @trevforum
No issue here.
Tried it through Amp as well as couldn't check that they were in UHD otherwise.
Mmmm Amp doesn't prove that it's UHD as Q box is set to 2160p 10 bit anyway.
How do you know in iPlayer that they are UHD?
Avatar for trevforum
Level 9 icon
Re: iPlayer UHD?
@oldfella wrote:
Hi @trevforum
No issue here.
Strange, all non UHD stuff plays OK but any UHD content gives me a black screen but with sound only.  Which Q box do you have, I have a V3.  All other content in UHD from other apps plays OK.
This message was authored by: C+r+a+i+g
Re: iPlayer UHD?
Does Sky Q support iPlayer UHD? I tried and didn't work, and its not listed here:
https://www.bbc.co.uk/iplayer/help/questions/supported-devices/uhd-supported-devices
Unless its a beta version?
iPlayer UHD works on the native LG (webOS) app, so no big deal for me its not on SkyQ box.
Re: iPlayer UHD?
Hi @trevforum
I have V2 box.
How do you know whether or not it's in UHD.?
UHD search brings it up but there is nowhere in the content that specifies it's UHD
Re: iPlayer UHD?
Hi @trevforum
@C+r+a+i+g  is correct and checking on the TV App the content is all flagged as UHD.
The Sky content is not.
Level 9 icon
Re: iPlayer UHD?
Programs are tagged UHD in the Sky Q app and play as a black screen for me.
Level 9 icon
Re: iPlayer UHD?
There is a new version of the app.  Here's the system info.
Re: iPlayer UHD?
Hi @trevforum
Changed to iPlayerBeta on Q and still no UHD labels here
This message was authored by: ozsat
Re: iPlayer UHD?
I've found the UHD on iPlayer on SkyQ is hit and miss. Currently I have the new version of the app dated today and UHD has vanished again. Yet all other devices are flagging UHD content still.
SkyQ Silver bundle (V2 2TB with UHD/HDR + two minis) in Sky region #71 (Oxford) using VirginMedia Gig1 Fibre (1.2Gbps/100Mbps).
This message was authored by: LGUser
Re: iPlayer UHD?
v3 box here and I have the same problem. Set to 2160p 10-bit and iPlayer shows a black screen playing UHD video. The sound is OK.
This message was authored by: Dazzasky
Re: iPlayer UHD?
Same for me, I get sound but just a black screen.
Re: iPlayer UHD?
Yep, sound & black screen, and the black screen is not UHD.
I noticed the native LG WebOS iPlayer version is also updated today, same version as SkyQ 25.17.5.0, and that still plays UHD just fine. I know its UHD, as the white is whiter, and the HDR logo pops up top right.
On the SkyQ sound, black screen and no HDR logo.
Seems someone may have pushed the 'launch' button a little early for the SkyQ iPlayer update?
Re: iPlayer UHD?
Also, apart from device on the iPlayer System Info, ther is one other suttle difference between LG WebOS and SkyQ iPlayers:
LG WebOS: Colour Depth 24bits
SkyQ: Colour Depth 32bits
Re: iPlayer UHD?
Hi @trevforum
My Q iPlayer App is showing Version 25.17.5.0. (Yours is 25.17.4.0)
Dont know if that is significant?
Different Device as well obviously as mine is a different box.
Still no UHD labels anywhere
Locked
