325
This discussion topic is read only This discussion topic has been answered Discussion topic: Virgin internet connection problem
Locked
This message was authored by: Scotty761
Re: No Internet Connection
Defiantly a Virgin issue, connected the Glass to my mobile broadband and it worked fine, I use O2.  Back to VM no internet connection.  I use my hub in modem mode and have a seperate WIFi mesh.  May try a different DNS setting to see if that works
This message was authored by: Carley1001
I am a virgin customer and I'm having the exact same problem! Has anyone figured out a way to fix this?
This message was authored by: Nikos
I'm also on Virgin Media and having the same issue. After calling this morning I should be getting an update from Sky later today.
This message was authored by: Andygroove
@Scotty761  But it 'could' be Sky now only working on sky/o2 connections ?
ive got EE , I'll give the hotspot a go and see
True, I forgot Sky use O2 for their mobile service. Changing the DNS to Google had no affect so still busted
Pucks won't let me in to change the network setting .....grrr. It thinks the connection is ok as it can see my router, but reports internet is down. So stubbornly refuses to let me change it
This message was authored by: Amber.p
Mine has just come back on.
I did a factory reset on the TV, all seems fine now.
Had to disconnect Ethernet to get to Negwork settings, successfully connected to my EE phone hotspot and everything worked.
so it's just Virgin I think
@Amber.p Ive got a rarely used puck in my office, i've tried a factory reset on it and im getting the same issue during setup. Connected to Broadband router passes, connection to internet fails.
Hi @Andygroove Try rebooting your router by removing the power cable for 30 sec then reconnect to reboot?
Then restart your Puck?
Done that, router and AP several times.
The only thing not working in the entire house are the 4 Sky pucks. (and trust me I have a LOT of devices connected in this Smart Home 😉 )
Factory reset did not fix the issue for me. Sky are working on it so should get a solution soon.
This message was authored by: GaryK85
Just spoke to someone at Sky and they confirmed it is indeed a Virgin Media issue. They are looking into it and trying to sort it.
Have Sky confirmed they are aware ?
Oh ok......Seen the updates
This message was authored by: DrunkMJ
Same here on my Glass & Puck, and yes I'm on Virgin Media.  But strange that Sky they are connected -
Locked
Answered - Go to Answer
