The content on this page may be out-of-date or have been superseded by newer information. Links on this page to other sites may not work and contact information may be inaccurate. This page has been archived for future reference.
25 Nov 2021 06:05 PM
Hi,
Have recently upgraded from Sky Superfast FTTC to Ultrafast FTTP.. Previously I used my trusty TPLink VR2800 with the superfast- much better features and more reliable that the sky hub.. I've now got the ONT and sky router 203 for FTTP and hate the router.. it's so crippled and locked down (no QOS and other features)- can anyone give me the config settings for the sky FTTP as I've tried with no joy.
I've set the VR2800 into router only mode and tried configuring it without joy.. Any help would be greatfully received as pulling hair out currently
Thanks!
25 Nov 2021 06:08 PM
You may have found that the dhcp option 61 has disappeared. The only way of authenticating is via dhcpv6 pd or get another router
25 Nov 2021 06:10 PM - last edited: 25 Nov 2021 06:10 PM
Can you screengrab your wan and lan screens and post.
To authenticate via prefix delegation :-
Select the WAN interface section of router GUI, then select dual-stack option WAN interface for IPv4 & IPv6, for the address select DHCPv6 (dynamic option not static), enable prefix delegation (PD) on WAN and then select SLACC for IPv6 creation method on LAN interface
25 Nov 2021 06:18 PM
25 Nov 2021 06:42 PM
I can't see any reference to slaac/stateless on the lan which is the requirement for address creation on lan to be pushed out to the wan for authentication
25 Nov 2021 09:45 PM
25 Nov 2021 09:53 PM - last edited: 25 Nov 2021 09:55 PM
Theres no vlan id on fttp. Disable it
Again @mae-3 @ anything to add
25 Nov 2021 10:28 PM
Posted by a Superuser, not a Sky employee. Find out moreWhat options do you have under Default Gateway?
25 Nov 2021 10:43 PM
It just has a drop down box under "default gateway" saying Current Connection.. I'm having to switch between routers currently and there never seems to be a time where the internet is not in use in this house!!
26 Nov 2021 06:50 AM
Again, the same question as @Skull+Treaty @cookiemonsteruk what options are under the default gateway dropdown list? And the VLAN as you have said @cookiemonsteruk is unset for FTTP.
30 Nov 2021 01:17 PM
Hi Guys,
Sorry for late reply- work been manic.. I think i figured it out (only think i don't have is working phone at moment as don't know the sip settings/how to connect phone to this router)..
Settings for VR2800 to use Sky FTTP are:
30 Nov 2021 01:21 PM - last edited: 30 Nov 2021 01:51 PM
There's no known way of getting Sky Talk over VOIP from anything other than a Sky Hub: the required configuration has not been published by Sky or extrapolated by anyone else.
30 Nov 2021 01:44 PM
Can the sky hub be run in a mode to turn off everything bar the sky talk and then bridge to my Vr2800? the phone would be handy, and would save us having to contact loads of people to say we've changed number etc 🙂
30 Nov 2021 01:45 PM
Posted by a Superuser, not a Sky employee. Find out moreSadly not, Sky Hubs do not offer a bridge or modem only mode.
30 Nov 2021 01:46 PM
Posted by a Superuser, not a Sky employee. Find out moreAs already mentioned you cant use Sky Talk on any other router than Sky's so if you wish to use your own router you'll need to keep the Sky router in play or abandon your use of a landline
