Discussion topic: TP-Link AC2100 - FTTP Setup
Locked
Re: TP-Link AC2100 - FTTP Setup
@Peterez
Sky adsl authentication is different re password and username
For ADSL2+
Username: install at o2broadband.co.uk (the at needs changing to @ and spaces removed)
Password: Leave blank
Connection Type: PPPoA
VPI: 0
VCI: 38
What other options do you have under ppp/atm for sky?
@Skull+Treaty
Is a manual config required for adsl2+ or is there a sky profile
This message was authored by Peterez This message was authored by: Peterez
Thanks that worked straight away. Everything seems ok for now.
@Peterez
Just interested what isp profile you used
From memory theres sky vdsl and sky mer vdsl
@cookiemonsteruk
From memory theres sky vdsl and sky mer vdsl"
I didn't use any profiles, I just plugged in the router and logged in and now it works.
Locked
