4
Discussion topic: Hive hub
This message was authored by Chris0435 This message was authored by: Chris0435
Hive hub
Trying to connect my Hive Hub and message just keeps saying " sorry we cannot find your hub check it's id number and internet connection"
Id number is correct and internet is working fine?
Chris0435
This message was authored by Chris0435 This message was authored by: Chris0435 Answer
Re: Hive hub
Hi
managed to resolve thanks I was trying to link it to the wrong email address. All working now 👍
Locked
Re: Hive hub
@Chris0435
Is the hive hub connected to ethernet correctly? Is the activity light flashing?
I am NOT a Sky Employee
Chris0435
Re: Hive hub
Hi
This message was authored by Andemma This message was authored by: Andemma
Re: Hive hub
Hi
i also have the problem where the hive hub doesn't connect to the sky q router
i have disabled sky shield
Any suggestions please
Chris0435
Re: Hive hub
Hi
My problem was I was trying to connect using the wrong email address so was my mistake.
once I used the correct email address it
re -connected okay.
Good luck.
Locked
