Discussion topic: Stream remote completely unresponsive
Message posted on 04 Dec 2022 12:04 PM
Re: Stream remote completely unresponsive
I've tried every option several times and I've had 6 devices delivered with the others working fine which suggests this remote isn't working (never has) Sky is so frustrating to communicate with - I refuse to spend an hour every time there is an issue on the phone in a que - you really do need to look at communication channels with your customers it's shocking
Message posted on 04 Dec 2022 12:23 PM
OK, I cancelled Sky Stream over a week ago and reverted back to Sky Q due to all 3 of my remotes having died and low and behold a new Sky Stream remote was delivered today (you couldn't make it up), I called Sky to ask what I do with it and they said " It's your's now,we don't require it back"..... So my next question is if anyone would like it just DM me and I'll post it FOC via Royal Mail.
Message posted on 04 Dec 2022 01:29 PM
Day 3 without sky stream. contacted sky regarding this, i was told that there is an issue with the sky stream romote, not other solutions offered to me. im paying for sky but cant get it. not very good customer service. tried calling sky today, im not waiting for over an hour to speak to an advisor. will i get a refund, probaly not. tried all of the online solutions, they dont work!!!
Message posted on 04 Dec 2022 06:53 PM
Sky remote not working
My sky remote isn't working I have changes batteries tried pressing 1 &3 and all that
Message posted on 04 Dec 2022 07:03 PM
I would urge anyone who is within the 14 day cooling off period to cancel their SKY Stream subscription and send the kit back. Leave it any later and you may regret it!! Until they can sort out the issues with the remote I dont think it is worth the hassle.
Message posted on 04 Dec 2022 07:52 PM
I'd have it if no one else already has 👍
Message posted on 05 Dec 2022 09:08 AM
One thing I tried and I think it has helped, I had some WD40 Contact cleaner, so I removed the batteries and with an early sprayed a little on the earful and wiped all 4 battery terminals. I was surprised the amount of black residue that came off a brand new remote. Since then I haven't had a problem with this remote, so I'm going to try it on the other 3. I'm not positive it's a fix but it appears to have helped my situation.
Message posted on 05 Dec 2022 09:09 AM
Should read earbud
Message posted on 05 Dec 2022 09:40 AM
Finally gave up on one of my remotes today and phoned the 0333 number to get a replacement.
Got through in less than 30 secs to a technician who said the cause has been identified and eliminated, all new remotes should be unaffected by this issue and it appears the backlog has been cleared so all new requests should be shipped swiftly and arrive in around 3 days. Apparently they were getting the courier to collect faulty remotes for a while, to investigate the cause, but this is no longer necessary.
Keeping my fingers crossed, but sounds good for me and anyone still affected.
Sky Stream and 2nd puck, LG OLED65G2, Yamaha RX-A3060 plus Harmony Elite and Harmony 900 controlling the 2 pucks.
Message posted on 05 Dec 2022 09:53 AM - last edited: 05 Dec 2022 09:56 AM
That's really good news. The problem, of course, is that there will still be thousands of remotes in our homes that could potentially fail.
I know it won't happen, but it would be useful if Sky could identify where the bad batch of remotes are and automatically send out replacements before more bad feeling is caused by inevitable further failures.
Message posted on 05 Dec 2022 01:35 PM
And on the 8th day...
My remote arrived 🧔♀️
Message posted on 05 Dec 2022 02:11 PM
still waiting for mine, hopefully this one will work!!!
Message posted on 05 Dec 2022 04:09 PM
Re: Sky glass remote has stopped working
The twisting trick didnt help but if it does help i used the remote from my sky puck.
Hold 7 & 9 for 7 seconds and then 1 & 3 and mine connected.
Sky are sending me a new remote.
Common issue that the lady assures me is well known and they are sorting out.
Job done. Thanks!
Message posted on 05 Dec 2022 10:29 PM
Well then seeing that other customers have faced the same issue as me. And that gently twisting the remote fixes the issue. Tried the same worked for me for a while then stops. Just been 2-3 days since I joined Sky Stream. Not happy at all. I'm getting a whole new replacement remote including a new puck as well. Let's hope that remote works well otherwise time to convert to Sky Q 💀
Message posted on 06 Dec 2022 09:50 AM
Can someone remind me of the process to pair a Q remote with Stream? Just had another Stream remote give up on me so until I can actually be bothered to rant at Sky & request yet another replacement I'm sticking with the Q remote.
I did pair one previously on youngest daughters TV but for the life of me I can't remember what I done to get it working!
