Discussion topic: Stream remote completely unresponsive
Message posted on 12 Oct 2022 12:57 PM
Re: Unresponsive Sky Stream remote
I just had the non-responsive remote issue... Sky Stream really is the gift that keeps on giving. Giving me grief. What a steaming pile. It's absolutely not worth more than the £20 I paid for it. I've had better dodgy unbranded Android streaming boxes from China.
I've just done the re-pairing thing so let's see how long that lasts.
Message posted on 12 Oct 2022 01:13 PM - last edited: 12 Oct 2022 01:55 PM
hi @Floydianslip i seem to remember a few people posting that they were smashing through batteries on the glass TV remote ( i am presuming its exactly the same control ) , maybe a reset / reconnect would help that as well? when i had glass i never had any issues with the control burning through batteries, so maybe a "not properly" bound remote is constantly doing something that the others aren't??
worth trying......
Message posted on 18 Oct 2022 09:45 PM
Re: Stream remote completely unresponsive
Yes - found the remote was fine by using it on my glass - the puck was the issue
had a screen when I first turned it on asking to pair the remote and couldn't get any further - remote should already be paired
Message posted on 18 Oct 2022 10:01 PM
Ours just skips straight to the Internet connection page as soon as its turned on but the remote does nothing. Guess it's just a waiting game until they open tomorrow to call and get help 🙃
Message posted on 18 Oct 2022 10:08 PM
My puck remote does this regularly. Usually after pressing the power button to bring the box out of standby. It'll act dead for about 20-30 seconds then suddenly decide to start working.
I've done a full reset and re-paired it a couple of times but the problem returns.
It happens with other family members - they've given up on Stream too.
Waste of time.
Message posted on 18 Oct 2022 10:21 PM
Had a dead remote too. Got 3 Streams and one of the remotes just died. Did not reset or then reconnect. Got a new one coming. It is not the puck as it will connect to all the other remotes, just one of the remotes dead as a dodo. Sky replaced it straight away. Also please note the battery in the remote are crap and one set batteries was dead also.
Message posted on 19 Oct 2022 12:44 AM
I had problems with the remote when I got the Sky Stream a couple of weels ago. Like you I thought I had not completely taken the pice of paper out on the batteries. Checked and there was still a bit left. Took that out and it still didn't work. Replaced the batteries, still nothing. Gave it a good shake and surprisingly it worked.
I think (but not sure) that it may go into 'sleep mode' if it's not used for a while, because I often have problems with it working, but the 'shake' seems to fix it.
When I go to turn the Stream on for the first time every day, it takes ages and a few pushes of the 'on button' for it to work. I've kinda just got used to it now.
Message posted on 19 Oct 2022 07:22 AM
@tb22 I find starting the unit using a single press on the Home button is more reliable. The power button is a toggle first push on second off by pressing it repeatedly you are toggling the puck on and off.
My 3 pucks normally start in under 20 seconds but occasionally take longer I assume when they are checking for updates. Also start up,times are improved if you set power saving to off and enable the stay networked option. Both Settings are in Start up and Standby.
Message posted on 19 Oct 2022 07:30 AM
@JessH13 I had the same problem when my Stream box arrived - remote was as dead as a dodo. Phoned Sky and they quickly sent a replacement. In the meantime I had an old Q remote which I found worked with the Stream box (mostly) so was able to complete the setup and it worked well enough until the replacement arrived.
I then found, after numerous attempts at rescuscitating the dead Stream remote, it did suddenly spring to life.
Message posted on 19 Oct 2022 09:12 AM
Update:
Spoke to Sky and spent forever going through the steps I'd already done a million times. Was told the remote works by WiFi even though Sky's own website says its Bluetooth 🤷♀️ finally by the end agreed to send a new remote out. Fingers crossed that solves the issue.
Message posted on 19 Oct 2022 09:23 AM
Hi @JessH13 i know you've gone through multiple try's of pressing 1&3 4&6 7&9 etc , but just incase the following worked for me when I had to reset my remote and it became unresponsive;
With sky stream box off , took batteries out of control, left out for few minutes, put back in , with box still off, pressed 7&9 then 4&6, turned box on , control worked then via IR ( I think ) then was able to follow on screen instructions to pair the remote and then pressing 1&3 when told to, for me 1&3 didnt work unless I had the remote working to a point and then was prompted on screen to press 1&3.
you've probably tried every combination, but you never know , could help 👍
Message posted on 20 Oct 2022 12:08 PM
Mine was dead on arrival yesterday, phoned SKY and very helpful lady took me through reseting the puck and downloading updated software which worked and remote now working. (Unplug power cable, hold down power button on understide of puck, plug powercable back in and wait for light to flash red and abmer then release)
Message posted on 20 Oct 2022 05:11 PM
Yes done all these steps but the remote is completely unresponsive. Not even any back-light in the buttons so can only assume it's got some sort of connector issue with the power. Was promised next day delivery of a replacement remote but it hasn't arrived so thinking of ringing and just cancelling all together. More hassle than it seems to be worth at this point when we've got a Smart TV with all the apps on it.
Message posted on 20 Oct 2022 05:24 PM
One final thing to try, press 7 and 9 for 5 sec and then 1 and 3 after resetting the box. No backlighting until it's paired and no red LED at all.
Message posted on 20 Oct 2022 05:48 PM
