The content on this page may be out-of-date or have been superseded by newer information. Links on this page to other sites may not work and contact information may be inaccurate. This page has been archived for future reference.
31 Mar 2022 07:33 PM
I have had SkyQ for a while but yesterday it started dropping sound for a few seconds randomly on live and playback. If you rewind a few seconds the sound is there and you can hear it. It's annoying but I cannot find any articles on it. Anyone assist?
31 Mar 2022 07:56 PM
Hi @MG2410
Try a Reset Settings in the hidden menu.
Press 1 & 3 together on the remote and follow onscreen instructions to re pair.
