2
This discussion topic is read only This discussion topic has been answered Discussion topic: Sky Pace box won’t turn on.
This message was authored by: Jk05
Sky pace box has red light as power going to it.
wont turn on
This message was authored by: Mark39 Answer
Re: Sky Pace box won’t turn on.
Welcome to the forum @Jk05 🙂. Just so you know, we're mainly other customers here.
You could try turning the box off at the plug for a few minutes to see if it recovers. If not, I'm afraid the box has developed a fault and will need to be replaced (it has lasted very well).
If you give Sky a ring, they'll probably be able to replace it for you. Cost will likely  be between £30 @and £65. Or you could obtain a used replacement from ebay, gumtree etc. You'll probably need to buy a Sky+HD box as older Sky+ that are still in working order are a bit rare. Or you could take the opportunity to discuss upgrading to Sky Q with Sky.
Locked
Avatar for Jk05
Thanks Mark39
thsts what I was thinking, have tried taking plug out and waiting to turn it back on.
Locked
