Discussion topic: On demand keeps failing
Message posted on 01 Dec 2021 09:02 PM
Sky plus on demand constantly getting failed download. Sometimes technical error somerimes item unavailable. Box reset, router reset. I see some other people have similar issue but nonword from sky? Im pretty sure its their end.
Message posted on 01 Dec 2021 09:06 PM
Re: On demand keeps failing
You could try using a different DNS servers in the boxes network settings
1.0.0.3
1.1.1.3
Are good to use 🙂
Message posted on 01 Dec 2021 09:07 PM
Re: On demand keeps failing.
Just tried again and its dine. However for last few days isbvery intermittent. I really assume sky have server issues (since the recent storm?) But if they at least acknowledged the issue i could stop wrestling with my kit and wait for a fix
Message posted on 01 Dec 2021 09:10 PM
Cant see an option for that in network settings?
Message posted on 01 Dec 2021 09:14 PM
IIRC you need to setup a manual IP address and the DNS options are provided there
Message posted on 01 Dec 2021 10:04 PM
If you are a BT Broadband customer then Sky are investigaing this as there have been a number of other people reporting the same issues as you.
Message posted on 03 Dec 2021 08:16 PM
Issue continues. Is up and down but tonight keep getting failed downloads again
Message posted on 19 Dec 2021 01:04 AM
Hi, did you find a solution to this as I'm having the same problem?
Message posted on 19 Dec 2021 08:26 AM
Tried the suggestion posted earlier in the thread?
