726
This discussion topic is read only This discussion topic has been answered Discussion topic: Sky Glass/Stream Homepage Problems
Locked
This message was authored by: C+E+H
Re: Sky glass
Using the voice control works, thank to the previous person who suggested this. All of my punks and Sky Q are not working too, so just assumed it was nationwide.
This message was authored by: d3v3
Re: The Home Screen on Sky Glass isn’t working
Both Sky glass and puck are just showing Sky Cinema screen. Home page isn't thereZ  Only way to get to TV Guide, Apps and playlists is through voice.  Have done full resets and the issue hasn't resolved.
This message was authored by: JohnyLuke92
Re: I turn on my tv sky glass and it just keep saying sorry there currently no programmes of this ty
I have the same issue, and I don't understand why you can't change the HMDI source either so I could at least play on the playstation or watch things through the playstation
This message was authored by: tony+tj
Would be nice to see a response from Sky on here,
This message was authored by: Mrsvizor
To switch to hdmi use voice control software say switch to HDMI 1 or whatever port 🙂
This message was authored by: Jarna
Phew thanks everyone i thought it was just mine lol yes used voice control to get to bbc1 news then just used the channel numbers to change channel. I have also used  the voice control to get netflix etc. hope they fix it soon 🙄
This message was authored by: Stephyp86
Mine doesn't work even when talking to the tv
This message was authored by: adamcara
same here...
This message was authored by: Monkey+Puzzle+Tree
Use the mic button on the remote and say TV guide until they fix it.
This message was authored by: Jade1325
Re: Sky glass screen stuck on sky cinema, won’t load from remote
Same issue here thanks to managed to pick a channel though voice control
This message was authored by: Leonie1616
Sky glass tv!!!
sky glass not working , as I can see , it's a wide spread issue , get it together sky and sort it out ..
This message was authored by: Tomasabs
Re: My sky glass says, sorry, there are currently no programmes of this type available.
I've just pressed the microphone button and said hello sky take me to to guide and it's working again hope this helps!
This message was authored by: Pontons
Re: Only getting A-Z sky cinema on sky glass
You have been extremely lucky , we've had a replacement tv, lots of teething issues to start  but now just seems to be one thing after another - wish I'd stuck with Sky Q
Yep, this is certainly not a good look for Sky!
You can use voice commands to navigate but the main menu is "not very well".
Hope someone at Sky realises soon and puts out an update to us all
This message was authored by: jooli74
i am having the same issue with my sky glass. how do i fix it???
Locked
Answered - Go to Answer
