Discussion topic: Sky Glass/Stream Homepage Problems
Message posted on 03 Feb 2023 07:05 AM
							Sorry there are no programmes of this type available
I can see people were having an issue with this around November 2022, but does anyone have this today? Does anyone know how to fix it or is it something Sky need to fix?
Had enough of Sky Glass
Message posted on 03 Feb 2023 07:06 AM
							Re: Sky glass menu not working
My sky glass is stuck as well on a-z of cinema homE button doesn't do anything tried unplugging but nothing.
							Re: I turn on my tv sky glass and it just keep saying sorry there currently no programmes of this ty
Yes it seems like the home screen is down, but if you use voice control you can access other apps
							Re: Only getting A-Z sky cinema on sky glass
Looks to be a server issue at Sky's end so nothing users can do to fix it. As others have posted you can still use the system either by using voice search or access the text sesrch using the .... button. So using voice sesrch say "BBC One" and you get Breakfast etc.
Should get fixed quite fast I would think.
							Re: The Home Screen on Sky Glass isn’t working
So it's not just me
							Re: Sorry there are no programmes of this type available
Same problem reported up and down the country.
Try using the voice control to go to a channel.
Not ideal, but at least you can watch something
Same here
							sky stream stuck on error no programmes of this type
both my pucks have this message this morning Sorry there are no programmes of this type available.
tried re starting puck and re starting router nothing
any ideas
Message posted on 03 Feb 2023 07:07 AM
							Re: Sky Home Screen Broken
Same issue here. Managed to get a channel on via voice control  but this really isn't acceptable.
Sky glass.
							Re: sky stream stuck on error no programmes of this type
Not ideal, but at least you can watch something.
							Re: Sky glass screen stuck on sky cinema, won’t load from remote
Same here
							Has anybody else got a problem with sky glass being stuck on sky cinema?  Both main tv and puck are
Both tv and puck are both stuck on sky cinema A-Z so I can watch a movie but remote won't allow me off cinema. Can anybody help me please.
Switched on this morning to be met with a blue screen and the message "no programs of this type available". Did the unplug/wait/plug in but still the same. Microphone works but really not an acceptable alternative to the home screen.
Message posted on 03 Feb 2023 07:08 AM
							My to guide stuck on sky cinema won’t show guide
When I turn to on it is showing movies on sky cinema and the home button doesn't bring up to guide
							Re: Has anybody else got a problem with sky glass being stuck on sky cinema?  Both main tv and puck
