726
This discussion topic is read only This discussion topic has been answered Discussion topic: Sky Glass/Stream Homepage Problems
Locked
This message was authored by: fr66ajc
Re: The Home Screen on Sky Glass isn’t working
Yup.. seems to be back as it should be.
It'd be nice of them to say oops though
This message was authored by: Floral1
Rubbish sky glass
Loved my sky glass for all of 2 months, down hill since then .
SkyQ was so much better
This message was authored by: ME+ZULU
Re: Sky glass menu not working
Mine is working, didn't need to do anything
This message was authored by: CatCat1
Re: I turn on my tv sky glass and it just keep saying sorry there currently no programmes of this ty
The issue is now solved and all systems now working.
Re: Rubbish sky glass
@Floral1 my system now working normallu
This message was authored by: StuTheEagle
Re: Sky glass screen stuck on sky cinema, won’t load from remote
Looks like they have rolled back the update as we are back on Entertainments OS1.0. Now working again.
This message was authored by: dewbre
Re: Sky glass not loading error message and no support available ?
Have you tried using voice control? I used mine to say TV guide and it took me to that and now mine is back to normal. Hopefully that will work for you bi gave up ringing Sky as wait was estimated as 40 minutes 🤦‍♀️
This message was authored by: correen+greege
Mine seems to be working now
Correen Gregge
It's a daily problem with Sky Glass
constant freezing Tv
not loading pages
now today it's stuck on sky cinema
we pay a lot of money For What!
then try to call and lines are always so busy
can't wait to cancel my sky glass
This message was authored by: BoatNick
Re: Sky glass
Just rung them and their message says there is a known problem
Sky engineers report a fix has been applied around 8.20am and the system should be working normally. Can confirm myown puck is going to the proper home screen from the remote.
Mines working now
Correen Gregge
This message was authored by: Ifonefreek
@Everyone - I just rebooted my Sky glass - turned off at mains and back on again - NOW ALL OK!!!!
This message was authored by: JohnBen
Sky Glass Access 3rd February
Had been trying since 5:30 am to move on from Sky Cinema but it was stuck on that screen with no response from the "home" button on the remote. All usual reboots tried. See now having gone back on that normal service has resumed. What's going on Sky. Already quite concerned with this system and the number of freezes and reboots that have to be endured. Seriously thinking about going back to the satellite where never had anything like the number of probs.Glass gives
Re: Sky glass
@BoatNick Issue should now be fixed if you want to try.
Locked
Answered - Go to Answer
