Discussion topic: Remote network problem
Message posted on 03 Feb 2021 07:21 PM
Re: Remote network problem
You were months late to the advert server conclusion to be honest but whatever makes you feel important. Bye now.
Message posted on 03 Feb 2021 07:23 PM
You knew about it for months and couldn't work it out? 🤣🤣🤣🤣🤣
Message posted on 03 Feb 2021 07:25 PM
For those new to this thread @Anonymous has some great advice so don't discount all of it as it may work for you.
Message posted on 03 Feb 2021 07:40 PM
I and many others couldn't. I couldn't configure a vpn using NordVPN and if you look at hundreds of posts the fact we know that the advert server is the issue doesn't mean there is a fix easily available. I also got the issue using BT broadband not just 4G which causes your theory a problem.
Anyway, you're the first **bleep** I've encountered on here amongst many other great people trying to help each other, so I consider myself lucky.
Message posted on 03 Feb 2021 07:59 PM
I knew you didn't really mean it when you said 'Bye' as your speedy response proves you were missing me.
The 4G aspect of my post is factual - run a few wireshark captures if you must. As for 'your' BT issue, I'm pretty sure I didn't mention BT in any of my posts.
FYI BT Broadband is different technology to 4G (Chalk and Cheese) unless you meant 'BT 4G Home Broaband'?
I've been called many things in my life but a 'BLEEP' is a first. Guess you're a little annoyed at being called out.
Having soooo much fun - You?
Message posted on 01 Apr 2021 07:46 PM
Is there any point in saying "me too".
What's the point of having On Demand if you can't download anything.
Message posted on 09 Sep 2021 02:03 PM
I got the same problem while downloading several episodes of 2 separate series.
I checked my dusk space and although there seemed plenty of room (>5%) I decided to try deleting some older unwanted stuff.
this stopped thie issue immediately on both occasions. Possibly coincidence but I doubt it.
I suggest you try it anyway.
Message posted on 10 Sep 2021 06:38 PM
Had it happen lots today. Box has something like 15% free.
It's so intermittent and unpredictable that personally I think anyone's 'solutions' are likely to just be coincidence.
Andy
Message posted on 11 Sep 2021 12:00 AM
The one bit of consistency I've managed to achieve is to download 1 episode at a time and make sure nothing else is recording either. This is not 100% but definitely seems to improve the consistency of downloading especially a series.
A
Message posted on 11 Sep 2021 06:16 AM
Suddenly my extra box in my bedroom the Q box's remote isn't working. Can you help please.
Message posted on 11 Sep 2021 06:18 AM
What steps do I need to take to activate my remote control on my Q box please let me know ASAP.
Message posted on 11 Sep 2021 07:41 AM
@Mrs+J+SHARMA you are not addressing Sky support when you post in the forum we are mostly customers like yourself.
This page will halp you find if your remote is broken or just not working https://www.sky.com/help/diagnostics/sky-q-remotes/what-would-you-like-help-with
Message posted on 30 Sep 2021 05:54 PM
Press and hold 7 and 9 on the remote to reset it. Watch for the red light to flash at the top. Then press and hold 1 and 3 until it says please wait on the screen. Then follow the on screen instructions to pair your remote to tv see if that helps 👍
Message posted on 29 Dec 2021 12:54 PM
I have had remote network problem come up as the reason for a failed recording - if you have the sky go app, you can find the program on there and select 'download to sky box' this normally sorts the issue out for me 👍
