Discussion topic: 2021 or 2022 oled choices.
Message posted on 26 Sep 2021 09:02 AM
Is there any techy reason to hold off oled purchase until next year.
Currently viewing 48" Sony.
This could replace 43" 4K non hdr Sony.
thanks
Message posted on 02 Oct 2021 05:22 PM
The difference between the JZ1000 and JZ1500 is the JZ1500 has a custom panel with a heatsink attached to the back of the panel, which disapates the heat faster that's produced by the OLED panel, this allows the JZ1500 to attain a higher peak and sustained brightness. The JZ1500 is worth the price jump over the JZ1000 and the LG C1
Message posted on 26 Sep 2021 09:04 AM
Re: 2021 or 2022 oled choices.
At this time of year, as you've got this far, it's worth waiting for the New Year sales to get a 2021 OLED bargain. Or wait until Feb/Mar for the new ones.
It all depends how quickly you want to replace your TV.
Message posted on 26 Sep 2021 09:06 AM
thanks HDR would be good, just don't want to miss latest standards with hdmi etc.
Message posted on 26 Sep 2021 09:12 AM - last edited: 26 Sep 2021 09:13 AM
@Donfor Black Friday is some time in November.
edit: 26 November.
Message posted on 26 Sep 2021 09:14 AM
I've since found my way to reports of dull HDR sports via Sony A9 oled.
This is smilar to t.v. I discussed in curry's recently.
Maybe I should have checked LG's.
The smaller screen is essential, even 50" could potentialy 'seem' too big.
thanks
Message posted on 26 Sep 2021 09:37 AM
@DonforReally you need to look at the specifications and if possible look at one working.
I bought a Sony which had all the HDR labels all over the box but in reality it did not have enough brightness (NITS) to show Sky's version of HDR to its best.
Message posted on 26 Sep 2021 09:40 AM
I' have a 65" LG OLED C1 that's very good and works well with Sky Q/HDR. I;ve not had the oppertunity to see it with live sports and UHD/HDR as I did not have an HDR box until recently.
For the recorded programs/movies that have HDR, looks good. IMHO, it would be better if Sky went with HDR10. HLG is notall that good for low end TVs or TVs not setup correctly. For example, if you have your TV set to be bright in SDR, then you can easily find HLG to be darkish. HDR10 works better on low end TVs or incorrectly setup TVs.
Message posted on 26 Sep 2021 10:12 AM
Check out Panasonic's new line of 48" OLEDs - they have superb image quality & have all flavours of HDR available, HDR10, HDR10+, Dolby Vision & HLG. Not the cheapest but they frequently win awards for their image quality.
BTW, domestic TV OLED panels are only cut in certain sizes, so you can't get a 50". The next step up from 48" is 55".
Message posted on 26 Sep 2021 10:26 AM
@Donfor @From various information circulating I would at least wait till after October 7th and Sky announcement
Auto-Correct is my enemy.
Sky Glass - No Puck
Message posted on 26 Sep 2021 10:41 AM
Worth noting that as resolution is the same, pixel density is higher on smaller panels. Personally I'm very tempted to try and hook one of the last of the 2020 LG 48" CX OLEDs which are now around £999 but contain the same components as their much more expensive models.
Message posted on 26 Sep 2021 10:44 AM - last edited: 26 Sep 2021 10:45 AM
This Panasonic could be ideal
TX-48JZ1000B
only minor feature missing is Airplay, only as ap 4k t.v. airplay 2 notification has never been used.
thanks
Message posted on 26 Sep 2021 10:55 AM
@Donfor wrote:This Panasonic could be ideal
TX-48JZ1000B
thanks
Not quite sure what you mean. If you have an Apple TV 4K box then the TV doesn't need Airplay. You Airplay direct to the box which then displays the content on the TV via HDMI.
Message posted on 26 Sep 2021 11:11 AM - last edited: 26 Sep 2021 11:12 AM
only mentioned Airplay as some t.v's support it, others don't.
I have used airplay lots from macbooks etc just thought i could test airplay 2 whilst purchasing new oled.
thanks, does skyq remotes work well witn Panasonic's
Message posted on 26 Sep 2021 11:34 AM
@Donfor wrote:only mentioned Airplay as some t.v's support it, others don't.
Sky Q remote links fine with my Panasonic. I don't tend to use it much though as I have a Harmony remote & hub for controlling all my AV kit with one remote or app.
Message posted on 26 Sep 2021 11:37 AM
Thanks all replies appreciated.
Pansonic seems sensible choice.
1000 nits 120hz.
I'll allow after 7/10 ref Oracle info.
wonder if this is the Hisense announcement.
