The content on this page may be out-of-date or have been superseded by newer information. Links on this page to other sites may not work and contact information may be inaccurate. This page has been archived for future reference.
11 Jun 2021 10:48 AM
Try connecting pc etc via wifi it should pick up the new ssid
Yes I never had any problems before using them
11 Jun 2021 10:50 AM
I tried that but it only picked up the powerline adapter.
11 Jun 2021 10:52 AM
Is adapter broadcasting old ssid or asus ssid
Should I try factory reset on the router and try connecting then
11 Jun 2021 10:54 AM
I didn't look any deeper as I wanted to connect using the ethernet part.
11 Jun 2021 10:57 AM
Ideally thats the way you want it. No factory reset as such just reboot the router then repair the powerlines
11 Jun 2021 10:59 AM
Okay i'll try that. Thank you. I'll let you know in a bit.
11 Jun 2021 12:20 PM
Hello again I've gone back to using ethernet directly from router. A couple screen shots for you. Do i have to do anything in regards to security. Much appreciated.
11 Jun 2021 12:22 PM
Did they come out
11 Jun 2021 12:26 PM
Not yet
11 Jun 2021 12:36 PM
Finally.
Images came out blurry on my end. What security ?
11 Jun 2021 12:40 PM
So I don't have to worry about security on the router.
11 Jun 2021 12:43 PM
