10
This discussion topic is read only This discussion topic has been answered Discussion topic: Problem with Gigafast
This message was authored by: Brangae
Hello everyone on April 13th I made an upgrade from superfast plus to gigafast, they gave me the activation date on April 14th, but it has not yet been activated, and if I go to "my orders" I see that there is a broadband order in progress, but if i see my plan it tells me i have gigafast active,both Download and Upload speed still the same as Superfastplus
500Mb down and 60/70 upload, Wi-Fi
This message was authored by: DanD90 Answer
Re: Problem with Gigafast
Provisioning of the new profile shouldn't require a reboot of your equipment; but in this instance u would recommend powering down both the router and the ONT for a minute to see if this kicks things into life.
Locked
Avatar for Brangae
unfortunately not working
What does My Sky say when you test your connection for download speed? WiFi from the Sky Hub isn't great and you will max it out around 500Mb. Can you test over Ethernet?
@Brangae
@DanD90  best thing would be an ethernet speed test from fast.com.
Avatar for Brangae
I can only use via wifi, I don't understand why they said that I have a broadband order in progress, if I go to my details they said Gigafast
@Brangae
Can you seperate the wifi bands to ensure your tests are done on the 5ghz band
- Log onto router and go to wifi
- Go to 5ghz band and untick synchronise 2.4ghz and 5ghz
- Go to 5ghz ssid and add -5g at the end
- Save
- Go to individual devices and assign wifi band accordingly
Avatar for Brangae
I never do that. Can u explain how to do it?
@Brangae
Type 192.168.0.1 into the address bar of a browser
Click on wifi
Login with username admin, password wifi password
Follow the steps above and make sure you use the ssid-5g to run test
Avatar for Brangae
@cookiemonsteruk
Thank you i will try tomorrow morning
@Brangae
The Gigafast package is designed to service a large, busy household with many simultaneous streams, downloads etc. It is not designed to push 1gbps over WiFi to a single device on a speedtest. You may not see any change to your WiFi speed at all, you'd need to use a cable.
I am NOT a Sky Employee
Locked
