2
This discussion topic is read only This discussion topic has been answered Discussion topic: Loose Cable
This message was authored by: B+Emery
Loose Cable
Dear Sir /Madam.     The problem is the cable from my dish to the reciever is routed from the dish via the guttering, as it dissapears around the corner is is now drooping down, apat from beeing unsightly I am worried that it will be come  damaged or unconnected.. Could you put this post through to the correct department please.    Kind Regards Brian Emery.
This message was authored by: Invisiblename Answer
Re: Loose Cable
I think you'd be better off arranging for a local aerial company to do this for you, probably a lot quicker than Sky and may be cheaper.  Remember that you own the dish and associated cables, so they are your responsibility
I am just another Sky customer!
Locked
Re: Loose Cable
@B+Emery  You're not talking directly to Sky and nothing wil happen on the back of your post.  If you have an issue wth the cable from your dish you need to call Sky, there may be a charge for an engineer.
Re: Loose Cable
Locked
