269
Discussion topic: Live TV: There's a technical fault with the channel/Please wait for the programme to load
Locked
This message was authored by Jporch316 This message was authored by: Jporch316
Re: Live TV: There's a technical fault with the channel/Please wait for the programme to load
Chances are it will be during the night when most pucks are on standby
43inch and 55 inch Sky Glass & sky live camera 3 Pucks on virgin media M350 hub 5x. 4 x sky mobile sims.
This message was authored by Gzimma This message was authored by: Gzimma
Thumbs up on the latest firmware release. Fixes the issues experienced with technical fault on live channels.
Graham
This message was authored by Robert+J This message was authored by: Robert+J
Received puck today and I've had two occasions when live channels fail with message "waiting for programme to load"
Turning off puck and disconnecting from mains then restarting does work but is a real pain.
is this a software problem? or is my puck defective?
This message was authored by Tim+Adams This message was authored by: Tim+Adams
Hi @Robert+J
It's a fault which should resolve overnight when Sky push out an update.
https://helpforum.sky.com/t5/Glass-Stream/Live-TV-There-s-a-technical-fault-with-the-channel-Please-...
Thanks,
Tim
Sky Glass with Sky Live, Sky Stream & Sky Protect - FTTP 2Gbps
Thanks Tim. Fingers crossed
This message was authored by PastonPassway This message was authored by: PastonPassway
So I've got the latest update, so far no more "Program is loading" or "There's a technical fault" issue, but still getting periodic freezing of the picture from Live TV.  This does not seem to be fully resolved for me at least!
Scrap that, just started with the "Program loading" message again so definitely not fixed
This message was authored by Staceymay88 This message was authored by: Staceymay88
@PastonPassway I've not even got the update- I presume sky glass gets it
From what I've seen in other posts, Sky Glass doesn't need the update, this is specific to Sky Stream
This message was authored by Fothergill1 This message was authored by: Fothergill1
@Staceymay88 The update is only for Stream pucks and not for Glass as the Glass TVs were not effected by the problem the update is fixing 😀 (I am also on Glass).
If my post has solved your issue please mark as an "Answer"
@PastonPassway I don't know whether it will help with your situation or not but I always reboot my system after an update (or when I change settings).
@Fothergill1 Will give that a try, Thanks
This message was authored by Miles1981 This message was authored by: Miles1981
Had the update overnight before last, and since then it seems to be ok... had a situation when the screen froze for a split second, but I'd take that over restarting the whole box each time!
hopefully future updates will resolve all the buffering challenges that people are getting as well, or at least that's what it seems with the screen freezing.
This message was authored by Unisoft This message was authored by: Unisoft
Yay. 02p arrived after two reboots this morning. Good so far.
Still no good after a reboot here, I know it's not my internet connection as well given it's a 360mbps connection, still get a lot of stuttering.  Going to try another factory reset
Locked
