Discussion topic: How to check speed for the Speed Guarantee?
Message posted on 04 Sep 2021 04:34 PM
Re: How to check speed for the Speed Guarantee?
Also fttp is a bit binary either the lose of signal light is off or red . Other things if you appear to be stuck conveniently at 100Mbps would be what ethernet network adapter is on pc fast 100Mbps or gigabit 1000Mbps. Also check ethernet settings on router is set to gigabit
Message posted on 04 Sep 2021 04:35 PM
Yeah I actually switched over from bt had 330 with them and never had any issues. But now starting to regret doing so. Also I'm using my mobile to post this as my internet just dropped again 🤦♂️
Message posted on 04 Sep 2021 04:37 PM
@cookiemonsterukyeah ethernet link is full gigabit but even if it dropped to 100mb for some reason doesnt really explain the slow speed shown in my speedtest.net result
The last test appears to be down over mobile is this etherneted. Ideally we need 1 done on pc or laptop
Message posted on 04 Sep 2021 04:40 PM
@cookiemonsteruk no this was done with my computer connected via etherenet linked @ 1 gigabit
Message posted on 04 Sep 2021 04:42 PM
Heres another example:
I also made sure that there where no other devices connected at the time of theese test
Message posted on 04 Sep 2021 04:47 PM
its weird too when it drops the ont still shows a connection (green light) to the PON. when I was with bt if my connection dropped which happened very rarely maybe 3 times over the course of 4 years I would see that the ont itself lost connection
Message posted on 04 Sep 2021 05:15 PM
Any chance of logging onto the router and go to the router stats page. Wait for over 10 seconds and then post the full table. This is not the line speed this is to do with tx b/s and rx b/s. Just keep the same workload on the broadband as you have been doing
https://community.sky.com/t5/Broadband/How-to-find-your-Sky-Broadband-router-stats/m-p/2855717#M1014...
Message posted on 04 Sep 2021 06:50 PM
Currently using a third-party router. I can show you stats from it if you want but internet is working fine now. When the problems occur I do try plugging in the sky hub which does not alleviate the problem.
Message posted on 04 Sep 2021 06:55 PM
Very peculiar problem your test show upload speeds consistent with ultrafast plus . Its as if a device was using almost all the bandwidth. Keep an eye on it and get back to us if things go downhill again.
