Discussion topic: How to check speed for the Speed Guarantee?
Message posted on 04 Sep 2021 03:54 PM
My internet has dropped a few times over the course of a week, Im still in the intial 14 day period so maybe this is to be expected. However when I go to www.sky.com/mybroadband to test my speed it only shows an estimated speed not my actual speed. Im on fttp so it doesn't show the connection speed in the router statistics page either. I would like to avail of the Guaranteed Minimum Download Speed and possibly cancel my contract if this continues but obviously if I can not test my speed then I wont be able to. Any help would be appreciated.
You can see below the results of the mybroadband test.
Message posted on 04 Sep 2021 03:55 PM
Re: How to check speed for the Speed Guarantee?
Message posted on 04 Sep 2021 03:56 PM
I cant post the screenshot for some reaseon 🤔
Message posted on 04 Sep 2021 03:57 PM
@storm720 Images need to be moderated by the forum so won't show straight away.
Message posted on 04 Sep 2021 04:02 PM
The line speed isn't visable due to the ont modem being seperate to sky hub which for fttp only acts as a router.
You would need to run a series of tests over ethernet on fast.com and post them here if you wish
Message posted on 04 Sep 2021 04:03 PM
my bad should have read the disclaimer before posting lol
Message posted on 04 Sep 2021 04:07 PM
Fast.com is accurate and as ethernet is 90-95% efficient so we can deduce a line fault
If you are on 150Mbps your guarantee is 100 Mbps
If you are 500Mbps then it is 200Mbps
@cookiemonsteruk I have used speedtest.net to test it.
11976853934
But sky states that "Speed check must be done using sky.com/mybroadband, the My Sky app or by speaking to one of our service advisors." for the Speed Guarantee
Message posted on 04 Sep 2021 04:09 PM - last edited: 04 Sep 2021 04:10 PM
In your case the sky tests don't work as stated. We'll wait for speedtest image to come
Message posted on 04 Sep 2021 04:12 PM
Im on the Ultrafast Plus package so my speeds are upto 500 with a minimum guarantee of 400. It has dropped well below this a few times for upto an hour.
Message posted on 04 Sep 2021 04:14 PM
Is it 400 my bad. Just so long as its not done over wifi via mobile as that is likely to be connected over 2.4ghz wifi
Message posted on 04 Sep 2021 04:16 PM
yeah any speed test I do is from my computer thats connected via ethernet to the sky hub
Message posted on 04 Sep 2021 04:16 PM - last edited: 04 Sep 2021 04:18 PM
That would be because it's wording which applies to FTTC and hasn't been revised for FTTP. There really isn't any good way to test full fibre speed, and ISPs haven't got the hang of how to deal with challenges that it's not delivering as it should.
Message posted on 04 Sep 2021 04:20 PM
@TimmyBGood Yeah I was thinking that but its a bit of a catch 22 for any FTTP customers.
Message posted on 04 Sep 2021 04:24 PM
Fortunately my BT FTTP typically 'tests' as slightly faster than the 150/30 it says on the tin. There's really no reason why it shouldn't, given the vagaries of high frequency signalling over copper no longer apply.
