This discussion topic is read only Discussion topic: Download speed not what I expected
Locked
Re: Download speed not what I expected
@Vld187
Dial 150 from your landline
Avatar for Vld187
This message was authored by: Vld187
thing is I only got the broadband with no telephone landline 😁
@Vld187
Witg g.fast your phone plugs into the router and you probably default to pay as you talk but the call is free
You can also get them on
0333-7591-018 from any other phone
This message was authored by: mae-3
@Vld187
The speed on Steam is measured in megabytes not megabits, so the result is multiplied by 8 to arrive at the speed for the broadband line that is in megabits per second (Mbps). So 18MBytes second is actually 144Mbps downstream speed. Everything looks good to me. 😀
@Vld187
There you go from the master @mae-3 himself 😁
@Vld187
Thats 144Mbps
This message was authored by: JPR007
@Vld187 There is your answer from @mae-3  if you are measuring your download speed using steam. By default it shows Megabytes (MB), not Megabits (Mb)...yes there is a different with capital letters....
There's nothing wrong with your connection it is working as it should be🤓
Zen Superfast (FTTC), Fritzbox 7530, Sky Q 2TB UHD v3 (x1), Sky Q Mini (x2), Alienware Area 51-M, Panasonic TX-65HZ1000B, Denon AVR-X6300H, B&W CM8 S2, B&W CM1 S2 (x2), B&W CM Centre S2, REL S3 SHO (x2), Panasonic TX-P42G30B, Monitor Audio RS6, Marantz PM7001 KI, Denon HEOS 1 HS2 (x2), B&W P7, iPad Pro 12.9" (5th Gen), iPhone 14 Pro Max, iPad Mini 6 (work)
** No - I have nothing to do with Sky **
Avatar for Vld187
thank you all for clarification ! that makes sense now 😂 appreciate
The Steam client stats:-
Avatar for Vld187
I get it now ! thank you sir for clarification 😄
@Vld187
Had me confused.com for a while 👍
Locked
