Discussion topic: Download speed not what I expected
Message posted on 17 Aug 2021 06:33 PM
Hi ! Can somebody tell me why my download speed is 18 mbps altough I`ve got the ultrafast offer ?
Also I`ve connected my router to my pc through a ethernet cable, everything is wired correctly and was checked by a sky technician. Dude said I should phone them but nobody picks up....could be some option from my PC ? the tech guy said that this is really weird because on his internet device tablet wtv he was getting 100 mbps at least. So why I`m getting only 18 mbps download speed ? cheers
Message posted on 17 Aug 2021 06:42 PM
Re: Download speed not what I expected
Are you full fibre ultrafast or g.fast
Can you post your router stats
https://community.sky.com/t5/Broadband/How-to-find-your-Sky-Broadband-router-stats/m-p/2855717#M1014...
Message posted on 17 Aug 2021 07:07 PM
I`m in gigabit ethernet
Message posted on 17 Aug 2021 07:12 PM
Thats not what i mean. Is your sky hub plugged into a seperate large box or a small g.fast master telephone socket. Can you post your stats as well we need as much info to have any chance of helping you
Message posted on 17 Aug 2021 07:23 PM
Message posted on 17 Aug 2021 07:26 PM
Sounds like g.fast. it can take a couple of days to push the correct parameters to your profile anything after you'll need to contact sky
Message posted on 17 Aug 2021 07:28 PM
Can you also post a speedtest over ethernet on fast.com
Message posted on 17 Aug 2021 07:30 PM
here you go sir
Message posted on 17 Aug 2021 07:33 PM
When was it installed ? And just double check your router settings in ethernet menu are gigabit
Message posted on 17 Aug 2021 07:34 PM
it was installed last friday and I double checked the gigabit option on ethernet
Message posted on 17 Aug 2021 07:37 PM
Waiting for fast.com stats to come thru. but everything else is spot on apart from the througput speed
Message posted on 17 Aug 2021 07:39 PM
could be some setting in Steam ? thats what I`m using for downloads so might be something
Message posted on 17 Aug 2021 07:40 PM
fast.com stats are 130mbps download....
Message posted on 17 Aug 2021 07:46 PM
Fast.com is by far the best site to use so i would be happy that your ethernet speeds are pretty much in the ballpark '👍 don't use steam myself so can't advise what settings would make make it faster
Message posted on 17 Aug 2021 07:49 PM
appreciate the help you offered sir but looks like I need to try getting in touch with sky because this is really weird
