Discussion topic: Problem with sky tv signal and telephone line
This message was authored by Hazir This message was authored by: Hazir
My signal output 2 is not working all leads are in correctly also my telephone line isnt working
Is this all connected?
This message was authored by Mark39 This message was authored by: Mark39
Re: Problem with sky tv signal and telephone line
No, they're separate issues. The signal issue is the result of a problem with your satellite dish, cabling or possibly your Sky box.
The phone line problem is unrelated. Do you have a dial tone?
Hazir
Thanks for reply back
There's no dial tone for telephone line and I think it's the cabling that's the problem with sky TV
If your Sky box is connected to a wall socket, you could try replacing the flyleads which connect to the box.
If that doesn't help and you have your own dish, give Sky a call to book an engineer who will investigate. If you're connected to a communal dish, you would need to speak to your landlord or property management people as they're responsible for providing a signal to your home.
If you have a Sky landline/broadband, report the phone fault to them  when you call.
to report both (assuming Sky is also your phone/broadband provider
Hazir
Great thankyou is there a number to call sky please  to arrange an engineer  it's block of flats where I live and I don't think it's the satellite dish as some channels are working  output 2 signal isn't working  I had some work being done by cabling not certain that's wat made it stopped working
Yes, you can find the number to call via the 'need more help' dropdown at the bottom of this page:  https://www.sky.com/help
Hazir
Thank-you so much for your help
On average, new discussions are replied to by our users within 100 minutes
