09 Feb 2024 06:26 PM
Hi, my elderly dad has just come out of hospital and confined to his bedroom . He wants sky TV in there so needs a multiroom of some sorts. Mum will be watching sky in the living room still. Will sky still supply a box with sky+ in main room? There is no internet at the house either. Thanks in advance.
10 Feb 2024 09:15 AM
Regarding SKY Q I think you may wish to read some notes I have made for people considering switching from SKY +/HD to SKY Q
SKY Q multiscreen does need a router for network allocation of addresses etc & I believe requires an internet connection for activation of the minis & a lot SKY Q functionality is designed around an internet connection. (cc @HeathHayle )
09 Feb 2024 06:30 PM
Posted by a Superuser, not a Sky employee. Find out more@Ian117 Sky no longer sell subscriptions or hardware for Sky plus even to existing active accounts
you would need to upgrade to Sky Q to get multi room
09 Feb 2024 06:34 PM
Posted by a Superuser, not a Sky employee. Find out moreYour option is to move to Sky Q, this is Sky's supported satellite servce, there is also the option of Sky Glass or Sky Stream, if you want to move away from satellite TV and use the Internet
09 Feb 2024 07:30 PM
Ok, so he needs a sky Q box then. Can that be set up without internet connection?
09 Feb 2024 07:36 PM
No 😞
09 Feb 2024 07:49 PM - last edited: 09 Feb 2024 07:53 PM
Posted by a Superuser, not a Sky employee. Find out more@Ian117 You would need to replace the sky + setup completely with sky Q or sky glass/stream in both rooms as you can't mix and match between the two
09 Feb 2024 09:55 PM
not that I know anything about sky Q but doesnt multi room with sky Q setup just need a network not the internet so couldnt they setup a router with just internal network access?
10 Feb 2024 12:45 PM
ah ok fair enough I didnt know the minis needed activation using the internet
On average, new discussions are replied to by our users within 100 minutes
