09 Feb 2024 02:22 PM
Hi all
2 x SKY+ HB Boxes at our property - downstrairs box showing Input 1 Signal Strength/quality as fine - input 2 both are empty.
Bedroom box - both Input 1 & input 2 are both empty?
Any ideas on a quick fix for the bedroom box?
09 Feb 2024 02:24 PM
@Roger18 wrote:
Hi all
This usually indicates an issue with one or more of the following:
You may have to call out a local satellite installer, unless you have Sky Protect insurance, to check/fix your system, another option is to move to Sky Q, as during the move all issues will be resolved as part of the install, there is also the option of Sky Glass or Sky Stream, if you want to move away from satellite TV and use the Internet
09 Feb 2024 02:31 PM
Thanks @Annie+UK
Sky Q ordered but not arriving till Wednesday 28th Feb. Just hoping for a quick fix to the upstairs box?
Regards
On average, new discussions are replied to by our users within 100 minutes
