16 Mar 2024 02:56 PM
hello. I have tried ordering sky gigafast and WiFi max, the gigafast shows available but it won't let me add WiFi max. When I phoned up they said it wasn't available in my area but I could have WiFi boost.
it is the new router which I am after, how can this not be available in my area?
has anybody else had any issues?
16 Mar 2024 02:58 PM
Do you have sky q tv with one or more mini boxes?
16 Mar 2024 03:01 PM - last edited: 16 Mar 2024 03:13 PM
@ScallyDeejay wrote:
it is the new router which I am after, how can this not be available in my area?has anybody else had any issues?
Yes, it's been posted before. We think the issue isn't the geographic location, it's that an address lookup shows the property has Sky Q, and Max isn't yet compatible with Q Mini boxes.
16 Mar 2024 03:08 PM
@TimmyBGood i still can't order either although i am on stream for over a month.
The issue has been addressed previously via back office by deleting everything sky q.
16 Mar 2024 03:10 PM
I had sky Q 2 years ago. Had steam since. How do I get it sorted?
16 Mar 2024 04:31 PM
Sorry was supposed to mean I'm on glass now. Used to be Q
16 Mar 2024 04:37 PM
Posted by a Superuser, not a Sky employee. Find out more@ScallyDeejay you should be able to order over the phone.
16 Mar 2024 04:39 PM
Apologies for late reply . We may be able to escalate this for you but it may be quicker to call sky
Basically you need to say that you think there are remnants of the sky q install on your account which is stopping you getting sky max. Ask if they can forward the case to the back office team to remove any remnants/artifacts of sky q from your account 👍
16 Mar 2024 06:49 PM
After a 40 minute and a 15 minute call earlier they said they are sending a form off to another team and I should get a response within 5 days.
should I go ahead and order my broadband now so that I get a go live date, and then add max later on?
or should I hang fire to order in one go? I don't want to get an old router then a new one
16 Mar 2024 06:54 PM
Sky max is not the be all and end all yet.. so take out the package and decide later 👍
16 Mar 2024 07:19 PM
It's getting a decent speed on WiFi I'm after. I'm getting 600mps wireless now with EE but my contracts up and not paying what they're offering.
but I know the sky hub 4.2 black, will max out at 400mps won't it on WiFi?
16 Mar 2024 07:33 PM
Not necessarily, but it's 802.11ac rathythan 802.11ax
I just think sky max is still in early development and whilst the max hub is wifi 6 the pods are wifi 5. But then again no devices really demand the full 1Gbps. If that is the case and you want that sort of speed you can buy wifi 6 routers as access points to blanket you house
17 Mar 2024 01:08 PM
If I place an order today and get Max added before go live will I get the new router?
17 Mar 2024 09:59 PM
@ScallyDeejay If you really want the router that is new, order SKY Max, but you have been advised that it is not fully tried and tested at present, with a few issues...
And if you have AX (wifi 6 ) clients then that is the router that will support them.
