Discussion topic: Sky hub
This message was authored by Leo5 This message was authored by: Leo5
Sky hub
My sky hub keep going off and on and I don't know what's up with it
Re: Sky hub
@Leo5
Could you post your hub stats
Also if the internet light is off or amber you can use the service checker in the broadband section of your my sky app using 4g/5g mobile data
Re: Sky hub
@Leo5  Is this the connection dropping or are you having a loss of power on the router?
Leo5
Re: Sky hub
The sky broadband just disconnecting from the sky and going red
Re: Sky hub
@Leo5  Have you tried running the broadband test when this happens to see if it finds any faults?
Can you please run the broadband test, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
