Discussion topic: I have changed from BT to Sky, but still not connected
This message was authored by Karen66 This message was authored by: Karen66
I have changed over from BT to Sky but still have no connection
To anything. When will this happen
Re: I have changed from BT to Sky, but still not connected
When did Sky say it would happen?
There's typically a minimum ten working day lead time for such a switch to take place (assuming we're talking about broadband)
Karen66
Hi TimmyBGood. The change over/activation date was identified as today. I'm just not sure how long it will take, its concerning as I work from home
@Karen66
Unfortunately there's always some risk associated with switching ISP (and potential down-time during the process) so it's not an ideal thing to do when WFH is a factor: neither domestic ISPs or Openreach are obliged to make any particular provision for this and realistically don't do so.
@Karen66  You should also be aware activation can take up to midnight.
This message was authored by lettice This message was authored by: lettice
It can be anytime during the activation day.
That in theory takes it up till midnight.
You will see a downtime when swapping over ISPs.
If it is still not connected tomorrow morning, report back.
Sky Community Superuser
Sky Stream (2 pucks), Sky Ultrafast + using Sky SR203 hub. Sky Protect kit tester.
