22 Jan 2024 05:20 PM
22 Jan 2024 10:25 PM - last edited: 22 Jan 2024 10:28 PM
@EmmaT If the password error is from trying to connect to the router's wifi.
Make sure the sticker underneath the router is in place & the sidd / wifi code can be clearly read.
Then give it a factory reset: while powered up, hold the reset button in for at least 30 seconds
(any shorter may just force a reboot)
Let the router boot up & sync, then try to connect again.
Let the forum know how you get on ! Or if you require more help !
Tom...
