09 Nov 2023 05:55 PM
I'm having lots of problems connecting my third party router from County Briadband since a firmware upgrade. Signal is in and out all the time. Spoke to a CB engineer and he has suggested after an hour on the phone that the best solution is a factory reset of the Sky Q box.
What do people think of this idea and has anyone experienced this before? If so with what success? Did you lose any recordings? Thanks!
10 Nov 2023 10:08 AM
Posted by a Sky employeeHi there, Mike1955. I’ve escalated your post to our Community Messaging team who will invite you to a private chat shortly and help you with this.
10 Nov 2023 11:20 AM - last edited: 10 Nov 2023 11:26 AM
@Mike1955 Sky Q dose incorporate a Network Reset.
No loss of recordings & easy enough to re connect,
I doubt that any benefit will be gained or network issues resolved by doing a full factory reset.
(3rd party routers can have a knock on effect with Qmini box stability)
Going down a full factory reset will undoubtedly delete any recorded programming, so beware of choosing the correct option before committing.
Tom...
10 Nov 2023 11:24 AM
Ok thanks. I've a busy day ahead so will pick this up later.
11 Nov 2023 08:42 AM
Have spent an hour on the phone to third party broadband provider and another hour with Sky agent. The case is still open as I now need to contact my broadband provider and the Sky agent said they would leave the case there until that happens
13 Nov 2023 03:36 PM
Posted by a Sky employeeUpdate-We are closing this chat now as this matter has been resolved. If there is anything else in the future we can help you with, please do not hesitate to reach out. Thanks.
20 Dec 2023 05:28 PM
Mike, we've got the same issue with County Broadband and Sky, how did you get it resolved in the end??
20 Dec 2023 05:44 PM
Please see my reply to John (unless you are one and the same?)
20 Jan 2024 09:42 AM
@Mike1955 Mike sorry to be a nuisance. Could you post how you got this issue with County Broadband resolved.
BTW I am not the John you replied to previously
20 Jan 2024 09:51 AM
@Addie15 Could you provide us with the resolution for this issue pleas.
There appear to be many of us County Broadband clients who suffer the same problem.
20 Jan 2024 10:10 AM
Hi to anyone who is unfortunately having the same Sky connection problem we had after the change in router address. I will work backwards, I was out in touch with someone senior on the technical side, Leon, who eventually,sorted the problem out. Basically, he restored the original two addresses, 5g and 2g, and we have connected ever since without any issues. Well, if you ignore the fact that the County Broadband app doesn't work and hasn't since the Sky problem was sorted out. This has been outstanding for weeks! I was thinking of deleting the app and starting again. But that's a small issue.
So how did I end up with someone dealing direct on the technical side? As we were getting nowhere, I emailed the head honcho at CB. I've used that technique with other service issues when I feel I am getting nowhere with the usual tiers of customer service. Funnily enough that is exactly what I did when our combi boiler failed two days running (even after an engineer fixed one problem only for it to repeat). British Gas head office did contact us and kept in touch until the issue was resolved - another long story.
leon told me that the issue we had would affect all CB users who have Sky boxes. Luckily, they had an ex Sky engineer on payroll who helped sort the problem out, it was clearly something that hadn't anticipated.
Good luck sorting your issues out, update this site as it helps us all, and do persist with chasing CB, here are the contact details I used:
CB CEO Lloyd Felton email (done this way as Sky Community for some reason won't let me post the actual email address!) his first name then dot then surname @ countybroadband (one word) dot co dot uk - no gaps - if that fails just search for CEO county broadband
22 Jan 2024 01:14 PM
Thanks Mike this is very helpful.
BTW The CB app will not work unless you have Smart WiFi set on at the router I.e. the single switchable SSID between 2.4 and 5ghz
22 Jan 2024 01:57 PM
Ok thanks John. Good luck sorting your problem out. I've contacted CB yet again so will see if they decide to respond this time. Otherwise it's back to their CEO!
22 Jan 2024 03:58 PM
Hi John - I emailed the CEO directly and to be fair they replied and resolved it the next morning.
In our case it was 100% how County Broadband set up their IP addresses.
The response from their technical team was 'The issue with Sky is that your router needs to have a public routable IP address, this has now been done so please test and let us know.'
It definitely resolved the Sky issue straightaway (after the normal power resets of the boxes, not factory resets).
They don't seem to do anything until you complain higher up enough though!!
22 Jan 2024 10:27 PM
Thanks Comic Geek.
The CEO email address has been blocked by CB now and it just bounces back.
So I guess I will just have to keep plugging away at the support team.
