Discussion topic: Asus DSL-AC88U FTTC Settings
This message was authored by Headsburst This message was authored by: Headsburst
Hi all,
i am having issues with getting VDSL linknup and working. DSL comes up with no issues.
im looking to change from the 203 router to The Asus DSL-AC88U
I am based in Scotland and its FTTC
bi
ut cant get it to authenticate and go live.
old Modem confirms its Traffic Type of PTM
Network Type is MER
I have left router off for 60mins after settings have been applied and still VDSL wont go online.
Have doen automatic IP
And also PPPOE as below.
Anny help appreciated
Re: Asus DSL-AC88U FTTC Settings
@Headsburst
In the uk sky use dhcp option 61 .
Change the pppoe to auto ip which should bring up client identifier (option 61) and enter
anything@skydsl|anything
The rest look fine
@Headsburst
P.S. also enable upnp
Headsburst
Thats the thing i dont get the Option 61
this is what i get.
Thats on the latest firmware also
Maybe worth while rolling back to an older firmware?
@Headsburst
Are you sure about that? Your screenshot shows firmware version 1.10.08 but the Asus website suggests the latest version for your router is 3.0.0.4.386
I am NOT a Sky Employee
